Page 25 of 64 FirstFirst ... 1521222324252627282935 ... LastLast
Results 481 to 500 of 1261
Thread: VCM Scanner 2.25 Beta Now Available
  1. #481
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Tomorrows beta should allow you to also filter out transitions. For example, lets say you wanted to only show the data where you were on throttle (over 50%) for 500 milliseconds, you could do something like:
    [50090.avg(500)] > 50 AND [50090.avg(-500)] > 50
    The -500 means take the average of the future 500ms worth of data points. It might seem confusing with the -, but the idea behind this is that typically, you want to make sure you've been in a certain state for X amount of time to allow the data points to pass your filter..
    So, typically, you might want to just have a filter that only triggers when you've been on the throttle for a short while, filtering out the transient stuff. Doing both the 500 and the -500 filters out the transients at the front and end of the range you're looking for.
    That is eff'ing awesome. I can't wait to try it.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  2. #482
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    1. Still crashes on me every time I try to type anything in. Error report sent. It crashes when it sees the "[". After I have a formula in there I can erase back to that without it crashing. Once I get the last digit of the PID # out of there it will crash again
    2. If I copy/paste something in it will go in.. but still doesn't work. This is when looking at existing logs.. have not tried it on live logging yet
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  3. #483
    Sep 2002
    Chicago, IL
    6,397
    If you put in a parameter that isn't supported by your channels, it will evaluate as 0. 0 is less than 100.
    We got this guy Not Sure, ...
  4. #484
    Sep 2002
    Chicago, IL
    6,397
    Also, the latest build is 2.25.2600.. They build about 7:15am central.
  5. #485
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Ah ok, I dl'd around 7am central. I'll try that one. That was why I posted the build #, just to be sure I was on the latest
  6. #486
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    I tried it with a simple one this time--EQ ratio. Tried filtering for EQ > 1, then tried for EQ < 1. Resulting graph is the same both ways, which can't really be right
    I'll try it with live logging in a few hours and see what happens
    Am I the only one having problems? I really want this to work.. especially the transient stuff mentioned a few posts back.
    (these are with the .2600 beta)
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  7. #487
    Feb 2006
    South Carolina
    1,525
    Stop breaking the software.
    Jaime
  8. #488
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Quote Originally Posted by ElecTech View Post
    I'm trying
  9. #489
    Sep 2002
    Chicago, IL
    6,397
    Post your log and your layout.
  10. #490
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Here ya go (and I'm really not trying to bust your balls, just trying to give you whatever is needed to get it going--hopefully I'm just doing something wrong and it's my fault)
    esc 2.25, 2.hpl
    Beta Layout.Layout.xml
  11. #491
    Sep 2002
    Chicago, IL
    6,397
    Bizarre, your files work for me.. I'm able to do > < = and see the change instantly.
  12. #492
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Weird.. I dunno. I may try totally uninstalled/deleting everything and starting from scratch and seeing how it goes
    I have 2 other computer, I'll try it on those too just to see
  13. #493
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    lol, my other one is even worse. On it, the plot vs. time and graphs are both staying blank no matter what I do
    edit: disregard ^. I opened the layout I posted earlier and the graphs/plot started working
    Same thing on the " [ " though.. as soon as I type it into the filtering function box, it crashes.
    Also the same in regards to filtering not working. I can copy/paste to get around the crashing but it doesn't do any filtering then
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  14. #494
    Jul 2013
    Huntsville AL
    164
    I get the same ^^^^^. Error report sent. Just using the default file with the NGK AFX Lambda added.
  15. #495
    Sep 2002
    Chicago, IL
    6,397
    I just put up a new beta, .2601, this should fix the crashing issue. Give it a try.
  16. #496
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Crashing is fixed
    Filtering is working on one computer and not on another.. I'll mess with it some more and report back
    edit: (laptop) well, filtering was working.. I closed the graph layout editor, went back to it, and now changes are back to not working. I haven't figured out what got it to work yet
    edit2: Tried on my desktop and it's working exactly like you'd expect it to. Not sure why I'm having the issue on my laptop
    edit3: went back to make another change to the filter on the desktop and now it doesn't work either. Anything put in the function field has no affect
  17. #497
    Aug 2012
    Melbourne Australia
    344
    Keith, is it possible to have:
    [SpanishOak.DMR(-1209599999)] > 0
  18. #498
    Tuner in Training Sparkey's Avatar
    Aug 2011
    Rochester, NY
    24
    Finally got around to testing the EIO in 2.25. Connected an AEM Wideband and the values in HPT were very wrong . The AEM settings provided by default in HPT are Output=(V/.5)+10, based on the information given by AEM the formula for this unit should be different. Should I expect to see User Defined Wideband/EIO settings coming like in 2.24 in the near future?
    2010 Camaro SS - Stock
    2005 Cavalier L61 Supercharged - Sold
  19. #499
    Aug 2012
    Melbourne Australia
    344
    Sparkey, you must have a different AEM wideband to mine (30-4100) as that formulae is correct for me (AEM quotes V * 2 + 10.0 but that is the same). My only issue is that I need to compensate for the ground difference.
  20. #500
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by Sparkey View Post
    V/.5+10 is the same as V*2+10, mathematically.
