Page 17 of 64 FirstFirst ... 713141516171819202127 ... LastLast
Results 321 to 340 of 1261
Thread: VCM Scanner 2.25 Beta Now Available
  1. #321
    Aug 2014
    14
    where can i find hp tuner version of the blue cat tool? I have beta access but cant find it..using todays update
  2. #322
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Quote Originally Posted by jake75 View Post
    edit-->Virtual Volumetric efficiency
    It's not under engine, airflow, etc.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  3. #323
    Aug 2014
    14
    Got it thanks. The VVE doesnt show when i open my tune. I have a E38 PCM. If i open a stock file it comes up. Also using .2301 update
  4. #324
    Aug 2014
    14
    getting this error trying to download today
  5. #325
    Tuner in Training Sparkey's Avatar
    Aug 2011
    Rochester, NY
    24
    I have only been playing lightly with the beta scanner since most of it is still in progress (need to use beta editor to get a successful file write to my P11 since the firmware update). I found the status bits of 2.24 pretty useful, is this a dead feature or is this being incorporated in another way that I haven't gotten to yet? 2310 installed.
    2010 Camaro SS - Stock
    2005 Cavalier L61 Supercharged - Sold
  6. #326
    Sep 2002
    Chicago, IL
    6,397
    status bits and the bitbucket display from 2.24 are now combined into the main channel configuration window.
    All your existing status bits should still work and be there.
    We got this guy Not Sure, ...
  7. #327
    Sep 2002
    Chicago, IL
    6,397
    Todays beta allows you to save/restore individual gauges/graphs (not charts yet...), as well as the display properties for the channels/gauges/graphs/plot
    This will make it much easier to share specific gauges or display properties with other users.
  8. #328
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Original OS or custom? Post the tune
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  9. #329
    Apr 2010
    11
    **Update**
    I've had some good some bad luck using VCM Editor beta v2.25.2310 . The Virtual VE (VVE) tables work good so far! Success editing the table and click "Calculate Coefficients" works good. I have an E38 ECU in 2009 Pontiac G8 GT.
    A problem with VCM Editor v.....2310 are the transmission tables options. I can open the trans tables, but "Open Compare" file causes the whole VCM crash. In other words, opening two tune files to compare highlighted differences in settings.
    VCM Scanner beta v..2310 <is not> working right. I can't edit which sensors or PIDs to scan log. I do not get log data collected for any of the sensors or PIDs that are shown.
    2009 Pontiac G8 GT // CamMotion EPS 218-220 .604"-.604" 113+2 LSA // PSI 1511ML springs // rocker trunion bearings
    // Camaro trans pan wide filter // L76 6.0L (DOD-AFM delete) // 6L80E // Pedders GSR struts springs // BMR subframe bushings
  10. #330
    Apr 2010
    11
    ***Updated resolved, see post #334-335***
    Another issue with the VCM Scanner......I uninstalled the beta v2.25.2310.....then re-installed the stable release v2.24.
    Problem is now the VCM scanner cannot read the HP Tuners "box". It alerts "cannot find VCM cable". So now I can't use the older v2.24 with my cable??
    I noticed on installing the beta v.2.25.2310.....that if upgrades the "firmware" on the cable box. Does this make the cable non-compatible with v2.24?
  11. #331
    Aug 2011
    Rochester, NY
    24
    Quote Originally Posted by fluidfalcon View Post
    I run 2.24 and 2.25.xxxx side by side. Since updating the firmware, I have had some difficulty flashing to an ECU on 2.24 but have had no issues using the 2.25.xxxx to flash the file. What I have been doing with great success is using the 2.24 scanner to log then do the editing and flashing though 2.25.xxxx. You might want to try reinstalling your drivers for the MPVI interface.
  12. #332
    Aug 2014
    14
    2012 GMC SD Bluecat Trans.hpt
  13. #333
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    It's showing up as a regular VE table for me. I.e., not virtual VE
    Airflow-->general-->Main VE. Normal IMCR Closed, Normal IMRC Open and VE DOD.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  14. #334
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Did you re-install the LATEST version of 2.24? It can't be an old one. Download the latest one if you haven't already.
    2.25 includes a firmware update that is not backwards compatible with older versions of 2.24. The latest 2.24 version is, however, compatible.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  15. #335
    Apr 2010
    11
    2.25 includes a firmware update that is not backwards compatible with older versions of 2.24. The latest v2.24.1165 version is, however, compatible.
    I did what you suggested and the MPVI cable works again with VCM release v2.24 . I noticed the beta v2.25 updated the cable firmware. I pulled down the latest update to v2.24.1165 and v2.25 (beta). You're right, I previously had an older version. Thanks sparkey, schpenxel & tech support.
  16. #336
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Good deal.
    If you have a pro interface your stand alone logging is now broken, by the way.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  17. #337
    anyone else getting this error in the latest beta? can't seem to do anything without the editor freezing up and showing this message.
  18. #338
    Aug 2011
    Rochester, NY
    24
    That is a pretty generalized .net framework error I believe. Kinda like a cars SES or CEL, tells you there is a problem and that you should look into it. Make sure your windows is up to date and if that doesn't take care of it a reinstall is where I would go next.
  19. #339
    All the previous versions work just fine. Its a W8 laptop everything is up to date. I remove and install previous beta and all is fine
  20. #340
    Sep 2002
    Chicago, IL
    6,397
    Post your hpt file that is causing the issue.. and EXACT click by click steps on how to reproduce the issue.
    Also... editor issues shouldn't be in the VCM Scanner section/thread.
