I sent in a request for the 2.25 Beta. It was like Christmas getting my tuner for the Challenger but then I found I have to wait in line for a beta version of the software to use it so it turned into more of a Christmas Vacation. Shitter's full! ;-)
2013 Dodge Challenger RT Plus - Shaker
New beta up?
yes.
We got this guy Not Sure, ...
No dice
(same issue)
Build 2616?
Post your log, layout, and exact steps you use to duplicate the issue.
Tuner by night
CPX Tuning
2005 Corvette, M6
ECS 1500 Supercharger
2007 Escalade, A6
Stock
Here ya go. Video is a little jumpy but should work well enough to see what's going on
esc 2.25, 2.hpl
Beta Layout.Layout.xml
https://youtu.be/R7G-4bDBYR0
Ok, new beta up. Try this one with the filters.
For reference, if the filter isn't supported (or malformed), it will always pass as true.
I haven't been able to break it again.. I'll keep trying :lol:
Thanks for taking care of it!
Now I'll begin begging for user defined variables
Tuner by night
CPX Tuning
2005 Corvette, M6
2007 Escalade, A6
Stock
This AEM is a 30-5130
I am aware of the conversion but I thank you for bringing it to attention just in case.
The transfer for this particular wideband is 2.375(Volts)+7.3125 I don't care if it is added specifically as I am sure there are just too many WB to accommodate all, but 'User Defined' transfer functions would fill that gap.
2010 Camaro SS - Stock
2005 Cavalier L61 Supercharged - Sold
You can change the output function on a lot of WB's which will obviously make it easier to get a WB going on 2.25 if yours isn't currently supported
Tuner by night
CPX Tuning
2005 Corvette, M6
2007 Escalade, A6
Stock
Should the new scanner be recording any quicker than the old one? A 1 hour log got about 300K frames (when exported) for me this morning. I don't remember 2.24 ever getting data at that rate. Or maybe I'm just logging less stuff now or something.
2.25 supports broadcast parameters, which will log faster, and allow requested parameters to log faster as well.
2.24 does not support that feature.
Gotcha. This was on an E38. I'll try on an E40 maybe tomorrow.. it always has gotten 20K frames/hour so I'll be able to compare better on it
Tuner by night
CPX Tuning
2005 Corvette, M6
2007 Escalade, A6
Stock
Small bugs:
-STFT B1 reports 100% all the time on the attached tune. Seems like this was fixed in an earlier release but I'm not 100% sure on that.
-The red dots that (presumably) indicate a particular graph has a filter applied don't seem to turn on/off correctly
esc 2.25, 2.hpl
Tuner by night
CPX Tuning
2005 Corvette, M6
2007 Escalade, A6
Stock
Attach your channel config please and I'll test on the bench.
Eventually I'd like to add the ability to extract a channel config from a log.
Here she be:
(this wasn't on a Corvette, that was just what I named it apparently)
Corvette Channel Config.Channels.xml
Tuner by night
CPX Tuning
2005 Corvette, M6
2007 Escalade, A6
Stock
new beta up that should fix the scanning issue with the misreported values.
This should fix a lot of misreported value issues.
Good deal. Will give it a go later. Apparently I need to do some work at the day job.
Should it show up correctly now when looking at old logs, or is it a matter of it now recording properly when recording new logs?
(i.e. my old logs look the same)
