I have a 05 Silverado 5.3l with cold air,long tubes,full exhaust, fully built tranny with circle d 3000-3200 stall,410 gears,224/228 .581/.588 112lsa cam. what can I set my rpm to for max. the cam powerband is 2000 to 6800 as per com cams. I have it set at 6500 fuel cut off with 6450 shift. I tried 6800 fuel cutoff with 6750 shift. man it seems to pull all the way there too even tho it seems it takes for ever to get out of 1st lol. I wonder am I doing damage at that rpm limit. and what will I need to set my shift speeds to with the wide open throttle in normal and performance section
