Like the title says upgrading the 2.7bar map in a 12 Cruze to a 13+ Cruze 3.3bar map. Do I need to use the '13 ecu image or can the 11-12 Cruze ECM Be made to run it?
You should only have to recalibrate the sensor settings in the engine diagnostics section. So you would use the year your motor is from.
