What I've got: 1995 Impala 383ci LT1, full bolt ons, 24x swap. PCM is a 0411
What I need: Info for what needs to be changed in the PCM. I've attached my starting tune. I've read something about the injector bank select needing to be changed and if the FP regulator is vacuum actuated (pretty sure this one is) I should set my IFR to a static all the way across???
Anyway, if someone could get me pointing in the right direction I can handle everything else. Just need to know what needs to be changed in the 0411 PCM to make it happy being in an LT1 Impala. I'll handle all the fueling / timing / other stuff myself.
Also quick note: I'm getting crank / cam position sensor codes even though the sensors are brand new. Should I do a case relearn?
Thanks in advance!
