Results 1 to 17 of 17
Thread: Help me, Delete O2 sensors
    Mar 2015
    Dallas, TX
    39
    Hello everyone, I just acquired my vcm suite, I want to remove my O2 sensors 2001 Chevrolet Silverado 5.3, I need your help to know that I delete or remove parameters.
    No more nothing to ask, I would greatly appreciate your help
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    Change all DTC's that reference O2 sensor 2 to "3 - no error report" and uncheck ses.
    Engine>Engine Diagnostic>DTC
    Ed M
    [email protected]
    Mar 2015
    Dallas, TX
    39
    Quote Originally Posted by mowton View Post
    Ed M
    If I turn off all the O2 sensor DTC, that way it would work the engine?
    Mar 2007
    Florida
    3,773
    Quote Originally Posted by Eli R. Morales View Post
    I didnt say all, I said all the ones marked Sensor 2. Sensor 1 are your primary O2's (control the closed loop fueling) and Senspr 2 are your secondary O2's which are only used to test the CATS are working.
    Also, you can turn off all the DTC's and the O2's will still work, you just wont know when the various diagnostics fail to alert you of a problem.
    Ed M
    [email protected]
    Mar 2015
    Dallas, TX
    39
    Ed M
    Thanks for explaining that part and I understand what you mean, but I want to work the engine in a way that O2 does not work, something like the open loop, or either work with the engine in open loop
    Advanced Tuner Road's Avatar
    Dec 2014
    Terrell Tx
    478
    Unplug the o2 sensors you don't want then delete any codes that set
    405
    2,315
    Set the closed loop enable temp higher than the engine will ever run at. I would say set it at 284 F but since you are from Venezuela, you may be working with C instead of F.
    Mar 2007
    Florida
    3,773
    Actually that is my bad, I read your wanted to remove the rear O2's, dont ask me where I git that from because when I went back and saw the answers I went ahhhhhh? :-)
    It seems the real question is you want to run in open loop....you can leave the O2's physically in or remove them (plug the bungs) at which you could disable both sensor 1 and sensor 2 DTC's in their entirety and as 2xLS1 said, set the closed loop enable to the highest temp allowed. I also disable the lt and st trim enables just for belts and suspenders. Before you start tuning, using the VCM, reset the fuel trims several times.
    Ed M
    [email protected]
    Mar 2015
    Dallas, TX
    39
    Ed M
    Today I did a test, turn on the closed top of the temperature loop, and also disable st and lt, but after that flashed I had a very bad result, to tell them that the truck was not moving anything in speed, was dead
    the only thing I did was unplug the O2 sensors and disable the codes, but at no time that drove not lit it any DTC's.
    That may be happening?
    Mar 2007
    Florida
    3,773
    Post your tune and log please.
    Not sure of your mods, please post them as well.
    Remember, now you don't have the O2's telling the PCM whether to add or take away fuel to maintain commanded AFR so if the mods/tune combo are off, it may not run very well untill you correct any fueling to make it run.
    As a quick question, why do you want to run without O2 sensors?
    Thanks,
    [email protected]
    Mar 2015
    Dallas, TX
    39
    Thanks,
    Today I'll try and keeps the tune and log, to publish it and see what the problem is, and heard people here who say there parameters that are connected with each other and now you tell me your on the values of fuel I see that it is so .
    I notrato only run without O2 sensors, if not also for the engine to operate at all times, because I want this? Here in Venezuela we are experiencing a high economic crisis because the damn government of shit we have, whether it is a dictatorship that we have, and spare parts for vehicles are too expensive and scarce, I can not buy sensors O2 and having already are defective
    Mar 2007
    Florida
    3,773
    Is it a stock truck?
    Also, understanding the language difference, can you re-iterate what is in bold for me please.
    Thank you,
    Ed M
    [email protected]
    Mar 2015
    Dallas, TX
    39
    Thank you,
    Ed M
    The truck is totally stock, sorry if sometimes do not understand the problem esq not much English and I write by google translator to take it to English, but sometimes the translator does not translate well.
    what I mean is, I hear that when you modify some parameters sometimes have to modify other because there are parameters that can be connected together, you you made me refer to something, because I you you said that if you disabled the close loop would have to modify the AFR parameters
    Mar 2007
    Florida
    3,773
    Got it, also make sure you est the fuel trims via the VCM feature.
    Ed M
    [email protected]
    Mar 2015
    Dallas, TX
    39
    Ed M
    in such a case that fuel parameters would have to increase?
    Mar 2007
    Florida
    3,773
    I meant to say reset your trims and then you will need a wideband. So the best to do is read the old trims and adjust accordingly. When I get home I'll help with this..
    Ed M
    [email protected]
    Mar 2015
    Dallas, TX
    39
    Ed M
    Thanks for your help friend, it would be annoying if you give me a contact drecto yours? If you do not want to make public send it to my e-mail [email protected]
    Thanks,
