Results 1 to 3 of 3
Thread: new tune afrer my cam 224/228 .581/.588 112lsa
    Mar 2015
    14
    can someone look at this log and see if they can find any errors on why my trk surge or stumble when real slow speeds coming to a stop or reversing. is the idle too low or too much fuel at them low speeds. afr usually around 14.6 to 14.8 at those speeds. and is there a way to get my afr around 16 to 15.5 after normal temps in park and gear. 05 silverdo with longtubes,cold air, full exhaust with electic cutouts, 3000-3200 circle d stall, built tranny,4.10 gears 24s rim
    Oct 2008
    Perth Australia
    161
    Add 100 RPM to Base Idle
    Add more Idle Airflow
    You have too much timing down low
    Mar 2015
    14
    ok will do and try
