Results 1 to 3 of 3
Thread: looking for a little input on 2004 5.3 truck computer in a swap.
    Mar 2010
    227
    A buddy used a 2004 truck 5.3 computer with the motor and pedal assembly in a 69 Camaro swap he did. Is there any thing other that VATS that needs to be changed for it to start? Motor is completely stock other than headers and air intake. I thought the truck computers did not have VATS but after looking at a stock truck computer I guess they do. I have worked on a lot swaps using fbody computers but not too many truck computers or drive by wire.
    1993 reef blue Mustang coupe
    Ls1 conversion
    1 7/8 cooks headers
    AFR 205 heads
    Fast 92/92 intake
    PAT G./ EPS Custom cam 230/234 .600”/.602” 112LSA +2 advance
    century Built 4l60e with Circle D 3500 converter
    4.11 gears
    13,533
    What transmission?
    Some other stuff will need to be changed if you arent running the 4L60e.
    But it should still start and idle with the VATS turned off.
    Mar 2010
    227
    Yea I'm pretty sure it's a 4l60e. I have to delete out some of the codes that won't apply on the 69 camaro. But just mainly looking to get the car fired up and running tomorrow. I didn't think to ask him but hopefully he got the tach box from the truck too
