Results 1 to 3 of 3
Thread: ngk afx wideband questions
    Jan 2015
    2
    I'm looking into getting a ngk afx or one of the new ones from Ballenger or dynocom. Is there any difference in the older model ngk afx and more recent ones, I'm looking at a used one that has a transparent red color case. I understand the sensor may be bosch vs newer ntk (any way to visually differentiate between the two?) Other then sensor and case is there any updates/and advantage to the newer widebands?
    Between the Dynocom and Ballenger is there a reason to go with one vs the other?
    Mar 2015
    5
    I recall reading that the new model has an update to increase accuracy or reliability and that you can send it to BM be modified for a fee.
    Tuner in Training bmotorsports's Avatar
    Mar 2008
    Richmond, VA
    34
    Quote Originally Posted by welldonecj7 View Post
    We offer all the replacement parts for the Powerdex AFX should you need any. We offer a 7ft, 13ft, & 24ft harness option. We offer the Bosch sensor or 3 NTK sensor variations. The Bosch & NTK are visually different ->
    Bosch Sensor:
    http://www.bmotorsports.com/shop/images/SNSR-01012.jpg
    NTK Sensor:
    http://www.bmotorsports.com/shop/ima...SR-01010-6.jpg
    Generally though, if you have the translucent red case controller (which is an older model) it will have come with a Bosch Sensor originally. There are no updates to the controller other than the case (yet). We offer a variety of sensors, so that is your choice. We did update the harness with fusing, loom that is smaller and has a higher temperature rating, higher end wire, and we make the harnesses here in the USA. You can upgrade our unit to an AFM1600 which increases the lean range and offers the ability to present lambda units on the display.
    Here is the product page with the full breakdown:
    http://www.bmotorsports.com/shop/pro...oducts_id/2337
