i need to know how to set up scanner to calibrate MAF sensor. also a walk thru would be helpful
does someone has a config already made for ls1
the maf tuning histogram in your config says its not supported
Lol you will need to add LTFT+STFT pids to your table you can do a search on how to do it.
http://www.hptuners.com/forum/showth...096#post121096
Here is a how to with link for the scan config from one of the best in the business. You'll have to do a lot of reading and trial and error will be your friend. Work through it slow and dial in the lower rpm and your not too likely to mess anything up.
1993 reef blue Mustang coupe
Ls1 conversion
1 7/8 cooks headers
AFR 205 heads
Fast 92/92 intake
PAT G./ EPS Custom cam 230/234 .600”/.602” 112LSA +2 advance
century Built 4l60e with Circle D 3500 converter
4.11 gears
