Hi Mates,
I recently flashed a brandnew ECU (E39A) with Vauxhall 2.0 SIDI Turbo Software.
Unfortunately I found out that the VIN will not be set correctly when you write a brandnew ECU.
I think the Software is on the ECU correctly,
the fuel pump primes when I switch Ignition on,
but it does not fire up and the exhaust does not smell like fuel.
So the ECU does not have the intention to start
Can this Troublecode stop the Motor from firing up?
P0630 - VIN Not Programmed or Incompatible - ECM/PCM
My VIN is still
VIN: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
But is that the problem that can prohibit Engine Start?
Thank you very much for helping me!
