Could someone please take a look at the attached files? I am working on a S197 3 valve with the following mods and it just isn't making power.
The vehicle came to me with the following mods,
Cams (unknown size, maybe ford racing?)
Ford Racing Intake (no IMRC)
BBK Short tube Headers
BBK Throttle body
Accel Coils (I hate these things but I don't think its the issue here)
Coil Air Intake
BAMA Handheld Tune (was running very lean, missing, 25% LTFT and still lean)
I started to retune, I have spark at 25-26 degrees at WOT, AFR is not in the logs but I dialed it in with a wideband, it sits between 12.6:1 and 12.8:1 at wot.
The pedal calibration is not finished, I'd like to tackle that after the other issues here are sorted.
The motor does not make any funny noises and idles alright. New spark plugs were put in right before tuning.
Other cars were able to make power on the dyno just fine.
In the logs you will see bank 2 is running lean. When scanning live the narrowband sensor readings are much closer to each other. Why is it worse in the log vs watching live?
I can't seem to find anything in the tune that would be causing the lean condition, can someone take a look at the current file to see if anything in the tune would be causing this? I have a hunch that the fuel crossover line is pinched on the Ford Racing Intake manifold but the customer 'swears' that it isn't. I'd just like a sanity check before I start taking the car apart.
Thanks!
Attachment 49083
Attachment 49084
Attachment 49085
I've included a stock 2007 mustang gt tune, the baseline tune the car came to me with, and "tune2" is the current tune with the changes I have made so far. Logs are below.
