Page 1 of 3 123 LastLast
Results 1 to 20 of 41
Thread: 2bar map sensor enhancement problem
    Hello , i trying to tune C6 LS2 wich was licensed earlier with single license. I did 2bar map sensor enhancement and now its asking to license it againe, otherwise it dont want to flash ECU... is it need to buy another license for this enhancement or some mistake occur??
    i thought this Enhancement is free? isnt it?
    Tuner 07MontRedcp's Avatar
    Jan 2007
    Arizona
    187
    What version of HP Tuners are you using?
    BJK
    APS TT 630 rwhp/654 rwtq @ 9 psi
    '07 C6, TR6060 conversion w/Z06 ratios. DTE Stage 4 Quaife Diff w/brace (3.73). Z06 Brakes, mild turbo cam & dual springs (222/222, LSA 115, .581/.581), LS9R clutch, LG GT2 Coilovers, Autometer Cobalt Fuel gauage, Progressive Alky Controller, and e-Boost2 Controller. PFADT poly bushing for control arms and Sports sway bars. MGW shifter. 3" B&B Fusion. RSI Stage 1.5 fuel system. RX dual valve catch can.
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by 07MontRedcp View Post
    BJK
    ^^This.
    Likely time to upgrade your 2.24 version. Click the 2.24 link on your customer page to get the latest version.
    Jaime
    Thanks you guys! i'll try, probably i have old version
    Ok, i made 2bar enhancement, saved the file, made entire wright, and trying to start the car but it dont work and giving me this
    P0106 - Manifold Absolute Pressure/BARO Sensor Range/Performance (Pending) (Current) (Immature)
    what problem? do i need to change anything else except that enhancement button?
    Jan 2008
    242
    Change MAP Sensor Linear & Offset.
    Is there any calibration section for MAP sensor in the VCMedit ? i didnt seen it yet ((
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    Quote Originally Posted by C5 2000 View Post
    Did you install a 2 BAR MAP sensor? What mods?
    Ed M
    [email protected]
    Regardless you'll need to re enter your map values under engine -diagnostic-
    06 Grand Prix GXP, LS4-full bolt ons, Tuned by me
    I did entered map values.... tryied even play with the numbers to get 100kpa with engine off... but nothing changed... the same DTC received. The car strats - works for a second or two and turns off... with that DTC... what else problem can be?
    BUT, when i flashed back stock file without 2bar enhancement and simply put map linear for 2 bar - the car starts and worked just fine with my 2bar sensor on idle etc... im just not sure if it can read over 110kpa in this state without 2bar enhancement option? Or what exactly that Enhancement do at all except sensor calibration??
    Mar 2007
    Florida
    3,773
    Quote Originally Posted by Stez View Post
    Sesnor must be miswired or wiring issue after install. Is it a good tight fit in the intake? Provide the part number of the 2 bar map sensor please.
    Ed M
    [email protected]
    Nov 2009
    All Around
    3,149
    ^ post your current file please
    Here it is
    and another question, if we run out stock MAF (60lg/min on 5000+) - should i be able to got on MAP further on 5000+ rpm... or i will need to get ls3 maf anyway?
    Mar 2007
    Florida
    3,773
    Can you please ask the question again, having trouble understanding your issue, sorry.
    Also still looking for the part number of the map sensor.
    Ed M
    [email protected]
    Quote Originally Posted by mowton View Post
    Ed M
    I meant we ran out our MAF sensor on about 5500rpm, its reached its maximum for about 500 g/s... so i was wondering if 2bar Map enhancement will help us to tune the car over 5500rpm... or we will need to upgrade our maf to LS3/7 one anyway...
    For a Part number of 2bar map sensor - i dont have one, this is the one we bought
    http://www.ebay.com/itm/171059434803...803%26_rdc%3D1
    Anyway im sure the problem is not in the map sensor itself, since it works just fine without that map enhancement! if im puting its MAP Linear for 190kpa in the Engine Diag section of stock tune map - it works just fine the same like stock sensor.
    Mar 2007
    Florida
    3,773
    Thank you for the clarification. As you are running out of stock MAF you have 2 options....1) Scale the tune -- cut all airflow/IFR values by a common percentage i.e 25% or 2) Tune in Speed Density using VE, I will look into the MAP sensor next...
    Ed M
    [email protected]
    Mar 2007
    Florida
    3,773
    I may have had a few too many vodka's, but how could that store offer a single 2 bar map sensor as plug and play with every LS version out there...there were differences in the wiring I thought.....
    Ed M
    [email protected]
    Ed M
    Vodka could help us )))))))))
    As for map sensor - it doesnt looks like the wiring is other since if im using stock tune with only modification of Map linear - this 2bar map sensor works just fine and shows up to 150kPa up to 6500 rpm. So the question is, to make tune in Speed density after say 5000rpm, should i just prolong VE limit from 4000 to 7000 rmp and turn MAP off after say 11500 Hz value in the Engine Diag window?
