I have a 09 SS running the following:
Injen upper
Hahn Intercooler
ZZP lower with MAF relocate
Stock k04
Hahn Coolram CAI
I have insane knock issues with the car and they make no sense to me anymore. I have been all over the car, wrapped pipes, torque everything, etc. I get these random knock fits that appear false 95% of the time. Last week the car was fine. I was having <3 degree knock spike on tip in only on number 4 right around 2800rpm. Everything else was zero. I had just clocked the knock sensors like I read on here. I parked the car and changed all of the brake parts. Did nothing else and everything is good and tight. I go to drive the car and I now have up to 12 degrees of knock on 1-2 and 8-10 on 3-4. I did a rewrite of the tune and it all went away. Now it is slowly coming back. It was 0 for a while, then 3-4, then 6's, and then back to 10's. WTF?!. How can it just come and go as it pleases?
This issue has been going on for a while now and I am getting pretty fed up with this car. In my quest to fix it I have replaced the following:
Both t-maps
Soldiered both t-map clips
The MAF twice with OEM new
Spark plugs twice now gapped at .032" once and .028" the second time. AC Delco stock.
Adjusted my wastegate rod
EVAP solenoids
Vacuum tank delete (mostly to get to the knock sensors)
What else code be causing the PCM to seem like it is learning to knock so randomly? Nothing is hitting anything anywhere.
Also, I have a very well verse and knowledgeable tuner so that is not the issue. I am using tunes that have been proven time and time again for years. I am not making any adjustments myself.
Questions:
Does the factory wideband control anything in the PCM, or does it just display data? Could it be bad and causing running issues?
Is it normal for VE airflow to lag 5-8lbs/min behind MAF airflow on a MAF relocate set up?
Should MAP (kPa), Boost Sens (kPa) and Boost Des (kPa) all be about the same under WOT?
ex: under 100% pedal I have 255kpa MAP, 207.2kpa Boost Sens & 254kpa Boost Des with no knock.
Why does HPT show all of this knock, but my RPD never sees any?
Sorry for the long post; I am trying to be as informative as possible. Also, my tuner is remote. I am mostly asking to see what I could be missing in tracking down my issues. This all started when I went to a MAF relocate after changing the clutch. Prior to that the car had 0.0Kr across the board at all times. Putting the MAF back into the intake does not change anything either, I tried that too.
