Results 1 to 6 of 6
Thread: Weird issue 2014 GT with TVS
    Jun 2008
    Tyler/Longview, TX area
    746
    I've got a weird problem. I attempted to make a cammed tune a week or so ago and realized very quickly that I was in over my head. That was the first tune I loaded on the car with HPT. The car would start and attempt to idle for 4-5 seconds and then die. Then I loaded a copy of the base Roush tune that I pulled off the car with changes for the fuel sys, injectors, axle gear, and tire revs, which should have run fine.
    I try to crank the car and it acts like I still have the cammed tune on the car. It runs for a few seconds and dies. I can load a SCT version of the base tune with changes for the injectors, fuel sys and gear/tire and it runs fine. What am I missing?
    Jun 2008
    746
    Is this possibly a problem with the Beta software? I will download newest version and see if it makes a difference.
    Feb 2006
    South Carolina
    1,525
    I haven't looked at your file yet, but I would say make sure the injector tables have the right units displayed for the values you are entering. Unlike in SCT, the table units in HPT are highly configurable and you may find there is a conflict somewhere.
    Advanced Tuner Witt's Avatar
    Aug 2006
    Pittsburgh, PA
    380
    Quote Originally Posted by ElecTech View Post
    This x2.
    Check your injector offset vs voltage number of decimal places.
    Jun 2008
    746
    The spreadsheet is in sec and HPT cells are ms. I will change and see how it goes. Thanks for the help!
    Jun 2008
    746
    You guys are awesome. It was the offset vs voltage(sec vs ms). Thanks again!
