Having a brick wall. As soon as I put this truck in gear it will start to crank full lean and will not add fuel, sits at 17.5 AFR If I just take it off the Closed position it will go back to taking away fuel because I have it pretty rich to get a response. What am I missing? Mass air flow has been removed. Came in from another tuner And had many issues from map senor connections to bad cam sensor. Had to be towed in because it wouldn't stay running.
Customer Doesn't know. Some one else built the motor. I will try. Map sensor vacuum was split off a vacuum log going to the valve cover originally. Lol. KPA 101 at turn of key. the thing will go lean AT 50 TO 60 kpa WITH NO LOAD and fat as a pig at 70 to 75 KPA and I don't see it in the tune.
Injector data does not appear to be correct, without knowing what injectors cant help you, but if stock fpr is still on should be same value all the way. Set maf high rpm disable to max value. And closed loop is disabled.
