I'm not sure if this should be here or in the bugs section but we'll start here for now. I'm seeing a discrepancy in what I have commanded in the spark tables vs what is being logged. I've taken this to extremes and have modified the tables as follows to verify the issue.
Main Spark Advance (HO, LO, and Alcohol tables)
100 kpa and below are set to 9.8 degrees
120 kpa and above are set to 0.0 degrees
PE (HO, LO, and Alcohol tables)
0.0 degrees across the board
Base Idle advance
100 kpa and below are set to 20 degrees
IAT Spark
ECT Spark
High TPS Minimum
Torque management
0.0 degrees across the board (default)
Despite these changes I'm still seeing +/-3 degrees of timing from the tables and occasionally as much as +-12. My assumption is that there is another table somewhere that's currently missing from Hptuners.
I've attached a quick log from a little while ago to see what you guys think. Is there anything else that you guys can think of that may be causing this?
