I am tuning my 01 camaro with a TSP Torquer v4, TEA stage 2 ls6 heads, bosch 36 injectors(fast), headers, etc.. I am doing the usual OLSD tune to get my VE dialed in and then running the maf to get that dialed in. I have noticed that while my final AFR is good on both tunes, my g/cyl readings are much higher with the maf hooked up than in SD. Is this normal or should I be looking for a problem somewhere? Also, my maf reading is pretty erratic. Am I better off just tuning SD with my setup?
I will attach the current tune and a couple of older logs to show the g/cyl difference between sd and maf. Thanks.
Joe
ps- 1.hpl is the sd log
