Results 1 to 7 of 7
Thread: 88 kpa @ 22% TPS?!?
    88 kpa @ 22% TPS?!?
    Guys could you help enlighten me what could be causing a high KPA reading at almost all TPS points and loads?
    I am seeing nearly 90 KPA at 22% TPS... 50kpa at 0% TPS??
    The car read the exact same with a brand new MAP sensor.
    The car in question is a 24X Converted LT1 with LT4 Heads/Intake, and an unkown Cam. Running a modified 2002 F-Body profile in the PCM
    Any input would be appreciated!
    Sep 2013
    SF Bay Area , California
    159
    I've seen low rpm idles at 80 90kpa on heavily boosted cars but NA should be 30ish. Log and tune please
    2001 Z06 : 856/830 : Built LQ9 403ci : D1SC 17psi : Self-built , self-tuned.
    Feb 2006
    South Carolina
    1,525
    Vacuum leak or valve adjustment issue.
    Well the valves are set pretty loose, right at zero lash with no additional turn.
    I will do a vacuum check, I believe we did once before and it was a very low vacuum. Maybe 4 or 5 inches
    The tune I was running around on was set for MAF tuning. But it does it on any tune.
    Heres the log...
    Sep 2013
    159
    Doesn't look bad , just the wideband is set up funky , I posted a solution in your other thread.
    I appreciate it man!
