Results 1 to 13 of 13
Thread: Biggest Duration @50, 95 LT1 24X with 0411 pcm
    Feb 2015
    7
    Whats the most/biggest Cam shaft you could run using the 0411 pcm?
    Feb 2006
    South Carolina
    1,525
    Bigger than what 95% of LT engines out there would need, IMO.
    Really very few limitations from an NA standpoint.
    Feb 2006
    South Carolina
    1,525
    I've tuned LT cars using stock LT PCMs that were in the 240's.
    Feb 2015
    7
    My recommended cam is in the 280 @ .050, will the 0411 pcm work with that?
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by WhiteMike03911 View Post
    Sure. I would run the 1 Bar SD custom OS for that one. It has an Alpha-N base VE modifier table that will help gain some resolution in the fueling because you'll have very little MAP to work with. Also the 0411 is only reall good to a little over 8000 RPM. What displacement is the engine?
    Feb 2006
    South Carolina
    1,525
    I should say that there is no table resolution after 8000, but I think it will still run the engine above that.
    Jaime
    Feb 2015
    7
    396, it should'nt go over 8000.
    Feb 2015
    7
    I've never tuned any efi stuff, I had a shop thune the car last time it was toogether with the 95 pcm and opti.
    Feb 2006
    South Carolina
    1,525
    That seems like a ton of cam for a 396. I hope you have a single plane on it. I'm not trying to question your intelligence, but are you sure that is @ .050 lift? Is it a COMP cam lobe? That's going to be a pretty healthy combo for a first timer.
    Where are you located?
    Jaime
    Feb 2015
    7
    Single plane, 13:1, 300 shot, AFR 227, Bullet camshaft. Just first timer at efi tuning.
    Located in Flint, MI.
    Feb 2015
    7
    Also on E85
    Feb 2006
    South Carolina
    1,525
    That's what I mean. Definitely go with the 1 Bar SD custom OS.
    Jaime
    Feb 2015
    7
    Thanks for the info.
