Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
Thread: LT1 24x help with low load/ low rpm driveability and cold start
    Apr 2009
    613
    I played with a lot of different things to try and smooth it out, was better but not silky! I had previously tuned the LT1 pcm and had no issues but something in the LS1 pcm doesn't like aluminum flywheels. Do some searches on that and you will find reputable tuners that took them out of their own cars because they are a royal pita.
    Nov 2013
    208
    Isn't that usually an issue with idle? I've not heard of a light weight fw being an issue with surging while driving. The super light 110 tooth fw and 7.25" clutch in the racecar I was talking about took a lot of work, and still occasionally stalls. BUT we have no surging at part / light throttle while driving.
    Jason
    Aug 2014
    Bend, OR
    94
    22815LTFT.hpl
    22815MAF.hpl
    22815VE.hpl
    So I did some more logging today. Changed dynamic airflow zone rpm and map boundaries to stock LT1 values (thanks Jason). Changed closed loop integrator delays and multipliers to account for the headers by adding about 25% to the values. Then went logging. The jerkiness was still there, maybe a little softer than before. The VE table looked richer than before after changing those settings, probably why it felt smoother. I haven't adjusted my VE or MAF tables based on these logs yet but I will tonight. For the drive home I made changes to the LTFT boundaries then re-enabled LTFT's. Still has that softer jerky feeling.
    1994 Trans Am: LS3 Crate Swap - Cam Motion 216/226-116+3 - 0411 PCM with Lingenfelter 58x > 24x Converter - 4L60E to RPM T56 - Strange 12 Bolt - UMI Suspension - TSP 1 7/8" Headers - GMMG Exhaust
    Nov 2013
    208
    I should point out that those are not the stock LT1 zones. Those are the zones I used once I installed the cam since like the stock LS1 zones, I didn't get to half of them once the cam went in.
    Jason
    what zones are you talking about that have to be changed???
  6. #26
    Aug 2014
    Bend, OR
    94
    Quote Originally Posted by JasonS5555 View Post
    Jason
    Oooohhh gotcha. I'll probably change them to my driving style then.
    Quote Originally Posted by capss9c1 View Post
    Under Engine > Airflow > Dynamic > Zone RPM Boundaries and Zone MAP Boundaries
  7. #27
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    This what I was taught a long time ago, assume it still holds true.....
    Map -- Low = approximately 5 kpa higher than kpa at idle, High = 80-85 kpa (s/b around your PE enable) and mid is 1/2 way between
    RPM -- Low = 100 rpm above idle, high = 2400 and mid is 1/2 between
    Ed M
    [email protected]
  8. #28
    Nov 2013
    208
    Thanks for the info Ed. I had always been told that the low should be below the idle MAP to account for the zones where you're at part throttle but decelerating. Is this less important than I had thought? My idle MAP is ~ 50 so I had set my low zone to 40....
    Thanks for all your help,
    Jason
  9. #29
    Aug 2014
    Bend, OR
    94
    Just to clarify, the low zone starts at zero and stops at the number you set correct? Just like the high zone starts at the number you set and ends at 105? (or 7000 if we're talking rpm) I figure there's 4 main conditions I drive this car in: idle/coasting, low speed cruising, high speed cruising, accelerating. My RPM zones are 1250, 2250, 3000. Pretty much all my driving happens between 1250 and 2250, most of my accelerating happens between 2250 and 3000. Looking through my logs, the MAP behavior is very different in these RPM zones so I gave each RPM zone different MAP values based on how I drive. The zone where the bucking happens (1250-2250 or Zone 1) has 37, 49, 79 as the MAP boundaries. When I'm coasting, MAP is always below 37. When I'm low speed cruising, MAP is always between 37 and 49. When I'm high speed cruising, MAP is always between 49 and 79. I changed the LTFT MAP and RPM boundaries to match. I haven't driven the car with these changes yet, probably won't notice anything but we'll see.
  10. #30
    Nov 2013
    208
    If nothing else, it gives the PCM more cells to store LTFT since you're getting to more than just a few zones with the stock boundaries.
    Jason
    1996 Camaro SS M6 - 24X conversion - stock bottom end - heads - shorty headers - 58mm TB
    Ultradyne 230/238 .565/.565 112+4 - 30 LB red top SVO injectors - LOTS of suspension...
    2002 GMC 2500 HD Duramax M6 - Just starting the tune on a stock motor now that I have a good clutch on order...
