Results 1 to 10 of 10
Thread: turbo 4.8 silverado injector duty cycle issue
    Apr 2014
    3
    i have a 2001 Silverado with a 72mm precision front mount, isky "triple 12" cam, deatsch works 60lb injectors, areomotive 340, 1218 springs, snow water meth, circle d 2c converter and a 4l80. I am running a 2bar os and the truck runs really good except when I try and turn the boost up to around 14psi or so it will go lean up top and I have noticed that the injector duty cycle will never go above 60% no matter what. I can try and add a lot of fuel up top and the idc will not go above 60, fuel pressure is a solid 70-72 psi wot. my tuner and I have looked through the tune many times and cant seem to figure out why the idc wont go past 60 so any help would be appreciated. I am also having a trans/converter issue that is also stumping me so I will post a trans log also for you to look at and express your opinion on what is happening there. it feels like the converter is trying to half ass lock after the 1-2 and 2-3 shift for a second or so and then it revs normally but this only happens at part throttle, wot it acts fine. converter was just cut and restalled by circle d 2 weeks ago and the trans is pretty fresh with a hd2. sorry for the long post but these two problems have been bothering me for a while and I have tried to fix them myself with no luck, thanks a lot
    ben
    2001 sd silverado.hpt2-13.hpltrans test 2-15.hpl
    Sep 2013
    SF Bay Area , California
    159
    I think your duty cycle issue is that you are actually running on MAF and maxxing it out. It's not disabled properly in the tune under engine diag > DTC's. The first 3 line items should be set to "2- No MIL light" not "3 - No error reported". And also you should zero out the MAF table in the tune just to make sure. Are you sure your tuner knows what he's doing? Cuz that's a rookie mistake. I don't know anything about auto trans, so I can't help you there.
    2001 Z06 : 856/830 : Built LQ9 403ci : D1SC 17psi : Self-built , self-tuned.
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    The 2 Bar Custom OS is Speed Density only so the MAF idea shouldn't be in play. What MAP sensor (p/n) are you using?
    Who set up the transmission tune? Was it Circle D? Is the TC stall 3200-3400?
    Ed M
    [email protected]
    405
    2,326
    IDC is just the result of a math formula. In order for it to go up either the RPM has to go up or the IPW or both.
    IDC = IPW x RPM / 1200
    Apr 2014
    3
    I am using the delco 2 bar sensor but don't know the pn off hand. I did the trans tuning myself and am by no means an expert. The engine side was done by a reputable local tuner and neither of us can figure out why the idc maxed out at 60%.
    Sep 2013
    159
    The 2 and 3 bar custom OS's do not disable the maf. I ran on maf only with 3 bar OS when I first completed my build. If you do what I said in my previous post , it should fix your duty cycle problem but you'll need to tune the VE.
    Mar 2007
    Florida
    3,773
    The gen iv os's do support MAF and SD. The GEN III from what I understand is SD only....
    Ed M
    [email protected]
    Sep 2013
    159
    Quote Originally Posted by mowton View Post
    Ed M
    The car in my sig is the one that I was maf only on 3 bar OS. Stock pcm. Gen 3
    Apr 2014
    3
    I changed the first 3 dtc to no mil light and took it for a drive and when it goes into pe it felt like it was on the 2 step cuz it was so rich. I think I may be headed in the right direction though just need to retune the ve and pe tables. Thanks a lot for the help so far and hopefully I get it running and shifting properly soon. On a side note, does anyone have a good trans test config that they wouldn't mind sharing?
    Mar 2007
    Florida
    3,773
    Quote Originally Posted by benloe View Post
    Hats off to nkautz for the find. Last time I will believe what I read..........why not "MIL on first error" and uncheck SES like normal OS's to get in SD???????
    Glad the car is coming around....good luck with the rest of the build
    Ed M
    [email protected]
