Results 1 to 3 of 3
Thread: My tune and log file
    Oct 2014
    1
    Hello Everyone,
    I've recently been doing incremental changes to my tune using HP Tuners. I also installed a WB O2 sensor, but I have a few questions.
    Is my O2 sensor showing the ~actual~ air / fuel ratio? I'm not sure if there's some interpolation that I have to do, or if its showing the actual ratio.
    During the run (log file attached) I did a couple of 0-60 mph and 0-100 mph runs; (starting at the 12:57 point in the timeline)given my mods, what are your thoughts regarding the performance?
    I've also noticed some "burbling" during coast-down from speed. What I mean is that under certain conditions, when I let off of the throttle, I get that gentle "popping / burbling" in the exhaust pipe. I'm thinking that this is a rich condition where the un-burned fuel is actually burning in the headers. Not only is this (probably hurting performance, but I'm sure that its no good for the fuel economy, as well.)
    I've got a '98 Coupe, LS1
    My pertinent mods are:
    LS6 intake
    Kooks 1 3/4 LT headers, X pipe, and axle-back
    3400 stall TQ converter
    My tires are Sumitomo HTR's (I know, I know....they're cheap, which is great because my 9 yr old son LOVES burnouts and donuts!)
    I'm curious to hear comments / suggestions regarding my questions and my tune file.
    Thanks in advance!
    KoreaJon
    Tuning Addict
    Jan 2015
    6,774
    Just from the datalog, you might want to take a look at your histogram #'s 2 and 3. You've got some decent spark knock - Could be false or real due to knock settings or multipliers. Either way needs to be addressed. I would recommend taking the timing out and seeing if it goes away. If it does, it's most likely real and needs to be addressed. Headers do typically make the "knock" felt or picked up by sensors more sensitive. As for #3, just looks like you need to tune in your VE table a little better. This will help the knock issue too.
    Popping on decel can be fixed by adding around 10 degrees of timing to your decel timing chart and by allowing dfco to come in a little sooner. Recommend changing one thing at a time and seeing what effects what.
    As for your sensor showing actual A/F. If you have a display on the sensor and it's a decent sensor, it should be correct. At that point all you have to do is set your datalogger up in correspondance. Recommend tuning basics at top - how to set up wideband.
    ~Greg Huggins~
    Sep 2013
    SF Bay Area , California
    159
    Looks like your wideband is reading a bit lean , improper configuration in scanner most likely. What brand is it?
    Popping on decel is probably just your DFCO being on , when I turn it off my car stops popping on decel.
    Try this for your spark table as a good starting point to work from and avoid knock. If it still knocks you've got something else going on , prob false vibration somewhere:
    Spark table.xlsx
    2001 Z06 : 856/830 : Built LQ9 403ci : D1SC 17psi : Self-built , self-tuned.
