Hey guys, first post, but I've used these forums for a lot of info in the past. I've been spinning my wheels (figuratively) with my 1950 Chevrolet swap for a while now. I'd appreciate some other perspectives and any advice you guys might have. Writing all of this stuff out helps as well.
Stats:
2003 LQ9
Magnacharger MP112
LS6 Cam and valvetrain
61lb/hr injectors from FiveO
87mm truck TB
4L80e
New PSI Conversion harness
History -
I previously installed the LQ9 in my C10 and it ran well. It was stock aside from headers and a tune back then. The engine hasn't run correctly since modified.
Originally ordered a tune via mail-order service hoping it'd run well enough to drive the truck to a dyno-tune shop. When the truck didn't idle correctly, I bought HP Tuners to see what's up and see if I could remedy it myself. I noticed a couple of things, but the truck still doesn't run reliably.
Situation -
Currently, the truck starts and idles high (1500-1900rpms) and LTFT on both sides are around +25%. RPMs hang up and take a long time to reduce if any throttle is applied.
I've been unable to find any vacuum leaks.
O2 sensors are new, and the same readings are coming from two different sets.
MAF is new, but I have a hard time trusting any MAF old or new from past experiences.
That's all I can think of now. I'm attaching my most recent tune and log file. I'd be interested to see if anyone can glean any relevant information from the attachments. Any input would be greatly appreciated.
note- Ignore AFR readings in the log. I'm having a hard time getting the PLX wideband to read as a pid.
Thanks guys.
