Have tried multiple multiple things to make this supercharged Navigator demand a lambda less then .88, including COT and it will not, like there is a clip. It is not torque or transmission related. Everything switches when it is suppose to on the WOT Fuel enrichment, but the demanded Lambda does not match the WOT Lambda table.
Note: it will demand more fuel, down to .84, with greater RPM but I am not going to keep running it up there that lean.
Eric, can you look at this calibration and see if there is a missing clip somewhere? I have it locked to go WOT fuel as soon as you touch the throttle by the way.
mod8.hpt
Ori Read.hpt
