06 TBSS(installed in a 72 commando) LS2 (24x) just swapped to 0411 pcm/LS1 conversion so I now have the single pole knock sensors on the side of my block. I'm getting P0327 and P0332 on my second run cycle. Based on some reading I believe the issue is that I need to make the KR tune/numbers more sensitive. This is my first attempt at using HPTuners so if I gummed this up let me know. Log file is a short drive with up and down hill, best I could tell there isn't a specific PID to monitor the KR sensors so I left the config in default.
I'd like to know if I'm on the right track or if someone has solved a similar issue. Searching shows alot of occurances of this, but not alot of solutions.
Here's my tune, log and config:
