Results 1 to 5 of 5
Thread: Spare ECM issues on 08 LMM - security issue
    Jan 2010
    23
    Need some help, missing something here.
    Got a used 08 LMM diesel ECM to have as a spare. Truck is also an 08 LMM. With factory ECM, truck is perfect. When the spare ECM is in it, I get the dead key and security message on the dic. I did license the spare ECM, programmed it fine with a know good tune, changed the spare ECM VIN to match the truck. Tried the 30 min key learn (3 separate 10 min cylces) several times and nothing. Still dead key and security light.
    What am I missing? Something different in the 08 vs the 06/05 down I am not aware of?
    Factory ECM I can program and truck runs perfect. Spare ECM I can also program, but dead key and security issue.
    Sep 2013
    8
    Did you write entire?
    Sep 2013
    8
    Quote Originally Posted by tc1 View Post
    After vats delete.
    Feb 2009
    1,931
    HPT does not do a write entire to the LMM pcm(not sure about any dmax pcm)
    Jan 2010
    23
    I will say Yes, I did push the full write button, I have read it really only does a partial as Mecanicman says. So what really happens regardless of what button you push is maybe the issue????
    I will say I wondered about writing the security parameters. I did try and turn off VATS on the used ECM, as well as change the Key cycle count and seconds of wait on the VATS and it did not appear to take effect. I cant see that it changed those area.
    So, what other questions.
    Thanks guys. I appreciate it.
