Just ordered a tvs2300,
writing up a base tune before it gets here...
-In the past I have had issues with 102mm throttle bodies. Addressing it via HPtuners is just a matter of getting the correct ETC scaler value and adjusting the idle airflow table. Is there a write up out there explaining what exactly is the effect of raising the values of this table? I mean I do it all the time with a cammed car its just I don't understand how it works exactly and what are the symptoms of raising the value too much versus reducing it. How would I go about messing with this parameter on my new supercharger and the Nick Williams tb.
-When it comes to part throttle ignition timing; on this particular car, the gto was never intended to be supercharged. Its compression is the highest of all the base LS engines (between LS1,LS2, and LS3). As a result I dont want to push my luck with the boost and will stick with the supplied pulley (6psi) especially since its a high mileage car. GM mapped out the timing tables for its OEM specs. So knowing this, it would be safe to assume that if I don't reduce the low end part throttle timing portions of the table I run a risk of getting some occasional knock.
Assuming that is true I see several ways to go about that...
1st- I can test drive the car and data log my daily driving routines. If I notice knock here and there just reduce the timing in those areas
2nd- Copy the low octane over the high octane table and advance timing across the map till I feel that the car gains no more partial throttle response/power or encounter knock
3rd- Download the stock tune file of a Vauxhall Monaro VXR500 which is technically a British supercharged GTO from the Factory with a MP112. (Have not checked the repository to see if it is available) and work off of that.
4th- Use the stock timing table from a ZL1 Camaro or ZR1 and work off of that
I just feel like option 1 is lazy and just crudely patching up any knock that may arrive. I want to experiment with different styles of going about this.
- I have heard things on the internet about how LT headers bleed off boost or reads as if you lost a psi or two on any gauge. Is this true? Or that 102 throttle bodies help pick up boost by a psi or two. Is it worth going through the trouble of tuning for this Nick Williams 102 on a stock supercharged ls2 or should I switch back too the stock throttlebody
Any advice or clarification on any of the mentioned points is appretiated
