I've got a collection of parts in my RX8 swap. Most of the stuff is reused from previous projects. I'm pretty sure everything works as well. I am swapping a 2004 RX8. I am using a PCM from a 2000 Z28, pedal and TAC from a 2002 Corvette, and an LS2 TB from a GTO. My tb has the 6 pin connector. Question is I'm unsure if the tb will work with the TAC or do I need an 8 pin Corvette one? I will flash the PCM with an OS from a 2002 Corvette as well.
