Results 1 to 7 of 7
Thread: Variable Cam Timing
    Mar 2010
    Texas Hill Country
    3,299
    Variable Cam Timing
    I need a little info on cam timing in the coyotes....
    anyone care to share? what are you guys doing with it? only adjusting optimum power numbers? etc.....
    negative values are BTDC and positive values are ATDC? is this only for the intake? is it opposite or the same for the exhaust cam?
    thanks
    Oct 2007
    Crawfordville, FL
    2,410
    Quote Originally Posted by Higgs Boson View Post
    thanks
    Couple of things. Cam timing is always referenced in CRANK DEGREES, so keep that in mind. Also, the values represent when the intake valve opens, and the exhaust valve closes.
    Eric Brooks
    HP Tuners, LLC
    Mar 2010
    Texas Hill Country
    3,299
    how much can they be moved without incurring clearance issues?
    Oct 2007
    Crawfordville, FL
    2,410
    On the coyote, there are two tables that are inverse of each other that prevents clearance issues. No Fly Zone so to speak.
    Eric Brooks
    HP Tuners, LLC
    Mar 2010
    Texas Hill Country
    3,299
    So if the tune shows:
    IVO: -30
    EVC: 0
    This is -30 degrees of overlap
    IVO: -15
    ECV: 30
    This is 15 degrees of overlap
    Correct or incorrect?
    Thank you.
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    IVO: -30
    EVC: 0
    IVO: -15
    ECV: 30
    Thank you.
    Yes, that's correct.
    Russ Kemp
    Mar 2010
    Texas Hill Country
    3,299
    Thanks Russ!
