2002 Trans Am, 411 pcm I believe, 6 speed manual 230/235 comp cam with 5 degrees overlap. Is there any way to get the pcm to use idle under/overspeed instead of cracker airflow to actually control the idle speed while the vehicle is still rolling? I don't understand why there wouldn't be any ACTIVE idle control when the car is rolling. The only thing I can do to keep the engine from dieing when I turn into a parking spot quickly is idle the engine up with the cracker airflow settings but idling into my gargage at 5 in the morning at 1100 RPM sucks.
