Results 1 to 14 of 14
Thread: coyote/copperhead ecu speed density tuning
    Jun 2007
    38
    Just getting started with tuning these computers and NA is easy of course. I plan on doing some supercharged vehicles soon though. I would assume these tables have to be adjusted when adding forced induction to these cars. They don't look like typical ve tables though. Where do the numbers come from? Is it similar to virtual ve on the gen4/5 gm computers?
    I haven't seen much discussion on these tables in other threads so I was hoping to get some good info on them.
    Oct 2007
    Crawfordville, FL
    2,416
    Quote Originally Posted by memphiss13 View Post
    It is a similar method to GMs, where for each mapped point, you have a slope, offset, and a quadratic term table based on RPM and zero aircharge. Most people are not changing the speed density section when going to forced induction. Some are using the Roush tunes as a base.
    Eric Brooks
    HP Tuners, LLC
    Jun 2007
    38
    Thanks Eric that clears it up. I was just looking at the roush tune earlier for this reason.
    Dec 2005
    222
    The speed density functions do parallel the virtual VE of the GM, though not quite as complicated from the perspective that the GM version is a higher order polynomial whereas the Ford version is, at this point in time, only quadratic. The Ford version has been evolving over the year starting with a simple array of airmass vs RPM, then to a linear solution and at present a quadratic solution. The difficulty in understanding the Ford version comes from its handling of the undesirable roots to the solution of the quadratic equation. When solving the quadratic, you have have solutions that involve a single root, multiple positive roots (i.e. two viable solutions to the same equation), and imaginary roots (i.e. square root of a negative number). The Ford logic has different if, then, else paths based on the solution set. Without following those paths, you'll get an inferred MAP (and hence predicted airmass) that is disjoint. Following the paths correctly seems to produce a good workable solution. Quadratic SD Map.PNG
    Jeff Chambers, Owner
    CRT Performance, LLC
    349 Cleveland Road
    Norwalk, OH 44857
    Ph: 419-668-4151
    Fx: 419-668-4643
    Performance Parts, Service and Dyno Tuning Specialists
    Dec 2005
    222
    As Eric has eluded, there are a number of operating surfaces. In the PowerPC applications its infinitely variable across (and determined by) the variable cam position for the 3V platforms. In the first evolution of the Copperhead, there are an infinite number of possibilities throughout the sixteen defined operating surfaces and with the newer Copperheads throughout 32 operating surfaces.
    349 Cleveland Road
    Norwalk, OH 44857
    Ph: 419-668-4151
    Fx: 419-668-4643
    Oct 2007
    Crawfordville, FL
    2,416
    Excellent explanation Jeff, thank you for posting it.
    Eric Brooks
    HP Tuners, LLC
    Feb 2014
    Quote Originally Posted by jchambers View Post
    Do you have a spreadsheet that can be shared for the quadratics?
    Thanks!
    so what is best for fi copperheads? how ford racing does it or the older ways of load tables? from what I can see the quadratics are going from 0-100 (example) in a even rising line but I don't get how that works w alllll the other speed density stuff. there isn't one person that can explain it in such a way someone that has not took a engineering class can understand or relate to. we need copperhead for dummies lmfao
    GOD HELP US ALL....
    Jun 2008
    Tyler/Longview, TX area
    746
    Quote Originally Posted by kaineoutlaw View Post
    LOL!! Amen!
    Mar 2013
    45
    amen
    So reading this thread, how is Speed density done when there is no MAP sensor on these cars stock? Is it based on the data supplied in other tables to supplement data in accordance to a MAP reading?
    Or do the Speed density tables must be adjusted when the car is boosted even tho there is no map sensor?
    Oct 2007
    Crawfordville, FL
    2,416
    Quote Originally Posted by Kaganader View Post
    The speed density tables combined together (each mapped point) form the inferred MAP. People get by boosting the cars without ever touching these tables, but to adjust them would help with transients and what not.
    Eric Brooks
    HP Tuners, LLC
    Thanks for the quick reply Eric.
    Tuner Blown383's Avatar
    Sep 2011
    New Mexico
    157
    Theoretically, if the formula for speed density is already mapped NA, wouldn't the same formula hold true for forced induction though the factory intake manifold, as we are just adding pressure to a known system? I know it wouldn't be quite perfect but it would have to be close unless you swap to a positive displacement supercharger?
    2007 Ford Mustang GT/CS: RGR 322 3v - JPC Intake - Vortech YSi-B - Magnum T56 XL - Built 8.8 - Full Suspension
    2008 Ford Shelby GT500: VMP Gen 2 - ATI 15% - SCJ TB - Full Bassani Exhaust - Full Suspension - Upper Pulley - Meth Injection - JLT 127mm
