Results 1 to 20 of 20
Thread: ATS/Regal ECU Pinout
    Mar 2009
    676
    Does anyone have info on the pinouts to these ECUs? Any idea if they're the same ECU? I don't know what their code is...
    Thanks!
    Matt K
    Feb 2013
    23
    best place to look for that is ALLDATA. that's where I got mine for the LNF, but not sure if its the same ECU
    Mar 2009
    676
    Yeah, that's what I figured. Anyone have access that they could snag that for me?
    Dec 2014
    Palmetto, FL
    874
    They do both have a K20 ECU. ECU pin outs are different, but if you are wondering if a computer would work from one of them to the other. I would say yes, would just need to be programmed to change for the different sensors.
    Mar 2009
    676
    It's not so much that I want to swap between those cars. I want to swap the E69 in my Solstice out for the Regal ECU. Should be a matter of swapping the plugs on the wiring harness, getting a TF tune to get rid of the VATS and VIN learn, and making sure the right wires go to the right pins.
    Dec 2008
    Nevada
    4,452
    i thought the regal ecu had vats access in hpt. only the E69 is locked down to the bcm if i'm remembering correctly.
    Dec 2014
    Palmetto, FL
    874
    I would say that should definitely be possible. You would just need connector view pin out of both ECUs. But just curious what is the advantage of going to the K20 ECU?
    Mar 2009
    676
    Quote Originally Posted by cobaltssoverbooster View Post
    I will have to check that...
    Mar 2009
    676
    Quote Originally Posted by Mark@TuckerPerformance View Post
    There is a whole lot more control in the Regal ECU. Many more tables unlocked since it is used in very many vehicles. Also, I thought it was the E39 ECU? Might be wrong on that though. Pull up a map of the E69 Solstice GXP ECU and one of the Regal ECU, you will see what I mean. Mainly, the flex fuel control is what I am after, but also just so many other little things. It would be like running a standalone for DI, but will only cost me around $500.
    Dec 2014
    Palmetto, FL
    874
    Sorry, yes you are correct. It is a E39 ECU. I have AllData and it was calling it a K20 ECU. Put I pulled a file for a 2012 Buick Regal GS and it does say E39. I also see that it does have access to disable VATS under HP Operating System. Well good luck with the project and keep us updated with the results. I would definitely be interested in seeing the results from switch to a ECU with more tuning support.
    Mar 2009
    676
    Will do, I want the pin outs to see how difficult it will be, I am not sure if all of the work would be worthwhile, or not...
    Dec 2014
    Palmetto, FL
    874
    2012 Buick Regal GS ECU Pinout. X1-Blue, X2-Black, X3-Grey.
    Dec 2014
    Palmetto, FL
    874
    Here is the rest of the pictures of the pinout for 2012 Buick Regal GS.
    Dec 2014
    Palmetto, FL
    874
    2008 Pontiac Solstice ECU pinout.
    Dec 2014
    Palmetto, FL
    874
    I hope those help.
    Mar 2009
    676
    That's what I need! Thanks for the help, I'll look over them in the morning.
    Mar 2009
    676
    I want to revisit this, since my car is down for the winter now for an engine build.
    Is this something feasible with the Regal plugs? Is it as simple as pulling the pins off of the E69 plug and putting them in the E39 plug (I know it won't be that easy)?
    The physical swap is the "easy" part for me to work through in my head, but what about a base tune? I don't quite understand how VATS and things work... does that mean I could run the E39 in my Solstice and have it communicate with the BCM for gauges and traction control and what not?
    May 2014
    Metro Detroit
    119
    i am almost certain the pins won't be the same. unfortunately you can't just de-populate the E69 plug and put those pins into the E39 plug. you'll either have to make a jumper harness E69 to E39, or cut your E69 harness, or splice into every wire.
    Engine operation should be very easy, since the LNF is basically identical to the LHU according to that other forum thread.
    Gauges... i have on clue, i would be very interested to find out, given the size of the OEM, i sure HOPE that they carry the same protocol and you can just plug and play for the gauges. Most of that stuff should be over CAN anyway, with a little luck it uses the same messages.
    Mar 2009
    676
    I would be fine cutting my OEM harness, as long as I knew the gauges and stuff would work when I am done. I have no clue how to find the compatibility of the CAN signals, that and the VATS (which can be turned off in HPT on the E39) are the two things most confusing to me.
    Did this get anywhere?
    What about the E-92 ECU for the LTG Crate Motor?
    --Christian
