Results 1 to 7 of 7
Thread: 2000 Bonneville SSEI VATS problems. Starts and stalls
    5
    I am new here but I recently swapped a L67 and 4t65hd into a rock crawler I built. I modified a stock harness out of a 2000 Bonneville and am having trouble with the VATS I think. It will start and 2 seconds later I loose injector pulse. It wont restart for a few minutes and cycling the key. I would appreciate any help on this issue. I have read the sticky regarding the VATS and I have set all of the dtc's to no error reported and have tried VATS to serial and pwm. still does exactly the same thing. Any help would be greatly appreciated. My file
    5
    Man nobody has anything? Anyone mess with L67 swaps? I know its old technology but someone has to have something.
    13,565
    I know the grand prix pcm's but havent dealt with a bonneville for this type of thing.
    5
    I compared it to a stock gtp file and I can't find any difference. Still having trouble not sure what to do.
    13,565
    Only thing I've found so far. Not sure how much it helps but does have some info.
    http://www.grandprixforums.net/threa...onneville+vats
    Feb 2006
    Canada
    1,958
    Have you performed the link? key on, wait 10 mins, key off and back on within 3 seconds...leave on for 10 additional mins, key off and then attempt start within 5 seconds? I imagine your security lamp was not part of the install here?
    2000 Trans Am WS6
    5
    well not sure. If im not using anything but the ecm do i still need to do that?
