Results 1 to 2 of 2
Thread: 05 Stang v6 question tuner help
    Jan 2015
    7
    Different type of question.
    I have an 05 Mustang v6, that has some pressure sensor going nuts somewhere when I put a full tank of gas in the car it won't start. We did the entire Charcoal canister and that helped with the random dying issue I had before. NO codes. Stock PCM, and everything else.
    However, I have the VCM which I use on my ls2 c6. Is there a parameter I could change to fix this issue if I bought ford credits? Even the dealer isn't sure what to do about it since it doesn't happen all the time. Modifying it is cheaper.
    I don't live in an emissions state.
    -Steve
    05 C6 Corvette, MN6
    Vararam CAI
    Full exhaust
    4.10 RPM Rear Diff
    Big Cam Specs Unknown
    Oct 2007
    Crawfordville, FL
    2,410
    Possibly. Depending on what the issue is, it may be something that could be disabled to fix it. Need more information, and I may need to add the parameters you need to the software.
    Eric Brooks
    HP Tuners, LLC
