Results 1 to 2 of 2
Thread: 2007 GT procharged automatic will not WOT command shift why me !!!!
    Aug 2014
    1
    Has anyone had this problem. Can not get commanded WOT shift points. Stock 07' automatic 5r55 procharged, ford racing throttle body. Can someone please god chime in.
    Dec 2005
    222
    Need to post your tune file. That trans has about six different modes of operation so you need to be sure that you're commanding the shift in the correct mode that its working in. Also describe how/when you're not getting the shift. Is it in normal, fast, MSA or tow/haul (OD off) mode? There are pedal rates that control which mode is active as well as the shifter position. Need more info.
    Jeff Chambers, Owner
    CRT Performance, LLC
    349 Cleveland Road
    Norwalk, OH 44857
    Ph: 419-668-4151
    Fx: 419-668-4643
    Performance Parts, Service and Dyno Tuning Specialists
