Results 1 to 7 of 7
Thread: Harness for Bench Tuning
    Sep 2005
    Apache Junction, AZ
    9
    I built a harness for tuning on the bench. It has the Red and Blue PCM connectors, DLC connector, On-Off switch and battery clips. The wiring is as follows. DTC connector: pin 2= Data, pin 4 &5= GND, pin 16 =+12V.....The PCM is 12200411, 2003 5.3. PCM wiring is pin 58 =data , grounds and constant and run/start power. This setup DID NOT work with my non HP Tuner scanner that IS OBD II compatibke. I have not yet received my HP Tuner Suite so the VAT is not masked.
    I'm sure one of you has solved this problem, if I have one?
    I built this to get a head start as the motor is a transplant for my '55 Chevy. HELP ??
    Dave
    HP Tuners Owner Chris@HPTuners's Avatar
    Mar 2003
    Melbourne, Australia
    5,329
    Re: Harness for Bench Tuning
    For the LS1 PCM you only need the blue plug, the pins are:
    1 GND
    19 IGN (+12V)
    20 +12V
    40 GND
    57 +12V
    58 VPW serial
    You also need a 12V battery or a 1.5A regulated power supply.
    Chris...
    I count sheep in hex...
    Sep 2005
    Apache Junction, AZ
    9
    Thanks for the reply Chris...
    Looks like I have the correct connections. I did ground pins 1 and 40 on the Blue connector. It showed it in my Mitchell on Demand diagrams.
    I guess that not having the VAT disabled is causing the problem. My HP Tuner suite will arrive in the next day or two and then the Fun Begins...
    Thanks Again,
    Dave
    Mar 2003
    5,329
    VATS shouldn't affect it. I can connect and scan LS1, V6, 4cyl, LS2, PCMs, ECM's, TCM's on my bench fine.
    Chris...
    Sep 2005
    Apache Junction, AZ
    9
    How right you are........I went over my wiring several times. The DLC is mounted on a bracket so I really could not see the top pin numbers, but I continued to validate a wrong connection. Today I took it apart to add a connection to pins 8 and 12. In doing so, I found the data pin 2 was actually in pin 7. A quick fix. All is well now..I am CONNECTED !!
    Regards,
    Dave
    Dec 2005
    KSA
    46
    What about the Green and Blue PCM connectors, should i use the same pins as the above post or the pins will be different?
    High Way Garage
    Location Saudi Arabia - Jeddah
    Phone : 966 504 655 105
    Custom Tuner:
    GM - Ford - Chrysler - Dodge - Jeep- All Europian Cars + Ducati Bikes
    HP Tuners
    SCT Dealer
    Diablosport Dealer
    Sniper Delta Force Dealer
    Viezu Dealer
    Alien Tech Dealer
    Dynojet 224xlc dyno soon
    Custom Tuning via Email Available
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,713
    Quote Originally Posted by HA-KSA View Post
    yup; just the blue connector is needed; same wiring
    Steve Williams
    TunedbyFrost.com
Similar Threads
  1. Your Guide to a good tuning experience
    By Bill@HPTuners in forum VCM Suite General
    Last Post: 10-27-2010, 12:59 PM
  2. Fuel & Fire vs SD vs VE tuning
    By MT_POKT in forum VCM Suite General
    Last Post: 07-29-2004, 01:11 PM
  3. Correct Tuning Procedures
    By Jax5.7 in forum GM V8 Tuning - Engine, Gas (Gen 3)
    Last Post: 04-24-2004, 08:09 PM
