I have a 2002 6.0 that I swapped into my 78 Camaro and I'm having trouble getting it tuned correctly. I have purchased the Master EFI Tuner GM EFI how manual written by Dan Maslic and followed the suggestions there along with other information I have gathered from reading plenty of post. However, I'm still having issues. My main problem that I can't seem to correct is initial startup, if I do not give the car gas and then let it idle back down slowly then it will try to hunt for an idle and then go dead. If I slow the idle down with the throttle to the point that the ecu catches it then it seems to be steady and will even catch itself when blipped, even though it is fluctuation by quite a few rpm which I believe the hunting is mostly due to the fact that I haven't figured out everything with the throttle cracker and follower. The engine when installed has long tube headers, cold air intake, and a comp cams XFI XE-R 281HR. Everything else on the engine is stock.
Attached are the latest log file where you will see that I had to get it started and then I blipped the throttle a few times to show that it would catch, also the latest tune I used.
