I originally posted this to the lounge, no hits so I'm moving it here.
We(NADC Hi-Po class) got the super charger, intercooler, heat exchangers and 2 pass system installed. (GMPP Stage II, 3" pulley)
This is an LE5 2.4, with VVT and I wanted to keep the VVT function, so I have to use my ECM(E67).
I asked for info about pinouts for the additional sensors...(Baro, SCIP, TMAP, IC pump signal and boost control)... no takers.
Did a little research, we found that an 06 Cad STS-V has a 4.4SC and it used the same ECM. So we wired in the additional sensors using the Cad pinout.
We are tuning using HP Tuners.
12/22/14 Dyno time! Most of the new sensors worked, except the IAT2.
This ECM does not have a real PE table...what a learning curve!
We got most issues worked out...Part throttle is good on MAF Lo...
It was very difficult to work on the MAF Hi with out getting into Knock Retard.
Got that worked out today! We posted 253HP and 303Trq on our Mustang Dyno. Now for street testing.
Any one have any ideas about IAT2?
The ECM shows 32* no matter what...it does not change.
Also we get Knock retard 3-4* on the first WOT attempt, but not much on 2nd or 3rd attempt. thanks
