My 04 GTO was originally equipped with a T-56, and I have recently swapped/wired in a 4L80E. What I would like to do is basically convert my current tune over to an A4 platform, keeping all of my engine tune/parameters the same, but I am not sure the best/easiest way to do that. The transmission is wired up as if it's a 4L60E so a stock A4 GTO transmission section(s) would suffice; even wired up the TCC PWM to the TCC On/Off in case I needed the functionality.
1.) I've been told that I can just take a stock A4 file and copy the information over using the compare file, but I suspect I will be left with having to purchase more credits to modify/upload a file with a different OS ID. Not entirely sure how that works, but I think that is the reason I've had to purchase quite a few credits for my car (8?) over the last three setups I've had tuned due to the shop not maintaining the same OS ID the last two times.
2.) From what I've read on segment swaps, the same OS ID is needed. I am not sure where to find an OD ID that will match my current (or past?; my OS ID is different now than it was stock).
In either of these cases, would I have to disable VATS?
If at all possible, I would like to keep from purchasing another set of credits for this car because as I said earlier, I have bought quite a few so far. I have tuned this car before when stock and with H/C/I, but since I've moved into the stroked/FI realm, I've traditionally had a shop do all of my tuning. I would like to take it back to them but trailering the car 3.5hrs away becomes quite a nuisance so I am going to try to get back into tuning it myself again. If this doesn't workout, can anyone refer someone that would be willing/capable to remotely tune my car?
Thanks for any help anyone can provide!
... first time tuning an auto... this should be fun
