Results 1 to 5 of 5
Thread: Wiring LM-2 to HP Tuner
    Apr 2005
    Sugar Land, TX
    1,198
    Which wires connect the LM-2 to HP Tuner? Previously with an AEM the white and black connected to 1 and 5 pins on my EIO connector worked. Same color wires with the LM-2 analog cable does not work with this LM-2. When I run the scanner while reading 14.7/14.8 on the LM-2 at idle I'm reading 7.35 on my laptop.
    Here's how I have my config set up. Title is still AEM as I just didn't change the name.
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Quote Originally Posted by 8850 View Post
    Should be using lime green and yellow for analog out 1 according to instructions.
    Perhaps you should read them
    http://www.innovatemotorsports.com/s...Manual_1.3.pdf
    Page 31
    Apr 2005
    Sugar Land, TX
    1,198
    Page 31
    Thanks for the info. Even if it did come with a touch of sarcasm. I had already found it though and ready to tune when the weather gets better.
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Sorry, I'm a bit frustrated with tuning on mine
    It should be against the law to sell injectors without proper data. I'm at the point of just buying some ID's and being done with it
    Apr 2005
    Sugar Land, TX
    1,198
    No problem....
    What I have, ID850s. I was upper 80% IDC with stock. Now 40% with the ID850s. 2013 CTS-V
