Results 1 to 3 of 3
Thread: GMPP E67 PWM help
    Oct 2012
    2
    GMPP E67 PWM help
    I am working on a 69 Camaro with L92 and GMPP ecu and harness. I have been trying to get the ecu to control the fans via a c6 corvette pwm module and I am not having much luck. I am running two spal 13" fans in parallel. I was hoping someone could look at the tune and make sure it is configured correctly. I am pretty sure it is all hooked up correctly:
    J3-64 is connected to pin 6 on the pwm module
    M+ is connected to fan +
    30 is connected to battery
    31 is connected to ground
    M- is connected to fan -
    I have checked all the grounds, power, continuity on wire from ECU to module, tried different fans, tested the module in my corvette.... so hopefully its the tune otherwise I am out of ideas.
    I copied all the data from 08 vette for the fans then changed the fan% vs ECT and ac, otherwise its the same.
    Pete
    Oct 2013
    550
    With that setup (E67 and Corvette Fan Control Module) the ECM fan control circuit is J3 pin 49 (not pin 64 - which is a non-used circuit).
    Oct 2012
    2
    That did the trick, thank you!
    Pete
