hey guys, i have an LS3 enigine, E38 ecu and using a T400 transmission.
Im using a pulse generator from dakota digital so the ecu can see speed. The original values were 40 in the VSS p/rev, at this value the ecu does not pick up any speed when im traveling at a cruising speed.
I have now got the value down to 1 but even at this lowest setting i can not get the ecu to see more than around 40km when my vehicles actually doing arond 90km on the road. I have put in my diff gear size (3.91 and correct tyre size 502.00)
This may have something to do with the gear reduction for a "cable driven speedo" in the T400 as the pulse generator is not getting a true figure coming exactly from the output shaft of the transmission.
what is the best way around this? do i opt for finding the smallest driven and drive gear for the speedo so the pulse generator is getting more pulses per tail shaft revolution and then adjust the VSS p/rev accordingly?
