This is my first time trying to attempt to fully tune a car. I'm using my car to learn. It's an 01 Trans Am. Prior setup was an Lq4 bottom end, stock 243's, ls6 intake, eps 226/230 cam. Now i have recently added ls3 heads, ls3 intake, 3-bar zr1 map sensor, FIC 80lb @3bar injectors, & a D1SC procharger. MAF has been removed so the car is being converted to speed density. I did the minor stuff to get the car to crank & idle. Now i need to know what i actually need to be looking at & changing to get it all fine tuned. I attached a copy of my current tune & a idle log i did the other day. I wire my wideband through the EGR. I need to figure out how to log it through hp tuners now. I would appreciate any help you guys can offer. In the mean time i'll be reading through the forum trying to gain more knowledge on all this
