Originally Posted by
mkriebs
Mark, GMTech did that set up himself, and it has been copied since. If you would like to DIY then you could look on DIY Autotune's site to get a bung like that. Then to control it, look into the split second controllers. Seems to be the best way I have found to do it, looks like I will be in it less than $350 with the bung, injector, controller, and injector wiring. You'll easily double that buying this set up from other vendors, and the ZZP style, though it works, leaves some performance on the table due to how it is set up.
As for power, you have a Delta or Kappa?
