Results 1 to 12 of 12
Thread: 0 to 5volt square wave tacho.
    Feb 2014
    Sydney
    295
    On an fg xr6t does anyone know if there is access to a 0 to 5volt square wave tacho signal.
    Feb 2010
    Perth Australia
    480
    No you need a tach driver to generate the signal.
    04 Velocity MKII M6 & 06 BF F6 555 ZF6
    Feb 2014
    Sydney
    295
    Ok
    thanks
    Feb 2014
    Sydney
    295
    Is anyone using a tacho driver to drive an aftermarket tacho and if so which one are you using.
    Tune with actual data not simulated data!.....Applied Road/track Tuning
    Do you need 1 pulse per revolution? I know some aftermarket gauges have dividers for difference cylinders.
    If so, one way I can think of is splice into the coil signal on number 1 & 6, feed them into a line driver chip (74AHCT125 or similar) and combine the outputs. That SHOULD provide you with a 5V square wave signal of one pulse per rev.
    Please note, I have never done this and am just thinking out loud. I am also assuming the PCM runs sequential spark and not wasted COP. If running in wasted COP you would only require signal from one coil
    EDIT: Coil driver is probably much easier, as hiddeous said. My thought process is purely based on using signals that already exist.
    Feb 2014
    Sydney
    295
    Quote Originally Posted by timwds View Post
    Timwds thanks for your response, basically what I am after is the ability to log knock on an FG as the tuning on my vehicle is finished with the exception of accurately knowing where the knock threashold is. It looks like the new scanner is a long way off, and even then I have asked on the forum if it will log knock with no answer.
    What I have done in the past is use the highly developed knock sensing ability of a Delco PCM to log map rpm and knock on other cars (using a GM knock sensor given cylinder size for the knock sensor frequency) and want to do this with the FG however there is no suitable RPM signal.
    Feb 2010
    Perth Australia
    480
    Just use this,
    http://www.ebay.com.au/itm/like/3711...pid=107&chn=ps
    I installed one on a mates BA a few weeks back to drive the rpm readout on the eboost - 5v square wave input.
    Feb 2014
    Sydney
    295
    Quote Originally Posted by hiddeous View Post
    Just use this,
    I was looking at one of these now you have confirmed the output I will buy one thanks for the confirmation.
    Advanced Tuner JETURBO's Avatar
    Feb 2013
    519
    If you dont have control of the sensor it will show phantom knock all over the place
    But the scanner is two weeks away so just hold on.......
    FG F6 400+RWKW .....10.9 @ 132mph.... FIRST 10sec F6 in SA ( sold )
    DYNO DYNAMICS 1200hp ...... Tuning weapon..... ( sold )
    OFFICIAL JONNY TIG INDUSTRIES SUPPLIER ..... Biggest and lightest intercoolers for B and F falcons
    SUBARU BRZ ......AVO TURBO KIT coming......soon
    VF R8 CLUBSPORT SV...... 340FWKW.....ASE BIG SINGLE KIT .....one day
    Feb 2014
    Sydney
    295
    Quote Originally Posted by JETURBO View Post
    The Delco system has had millions spent on its development no aftermarket system comes close!
    Two weeks! hmm I think your last prediction maybe more accurate!
    Oct 2011
    QLD, Australia
    436
    They look similar to the Autometer one Luke, I used one of those to run RPM input into the Eboost, works wicked
    Ford BF Turbo Ute,Stock head/cams, In house built bottom end,Atomic Springs, Forged Rods,Cosworth Pistons,Atomic Billet oil pump gears,ARP Head/mainstuds,Process West Stage 3 Cooler Kit- Plazmaman plenum,Precision Int.Gate 6466,Manta twin 3" exhaust,ID1000s Plazmaman surge with Holley 12-1800 pump, Home Built ZF6H26, On United Pump E85 499rwkw 10.5@135mph https://www.youtube.com/watch?v=dgZupPhrMss
    Latest mods, FG intake manifold conversion and ID1300s-500rwkw, Yet to see the 1/4Mile
    Feb 2010
    Perth Australia
    480
    Ive been running one of these for years-
    I don't think you can get them anymore though
