Picked up a Surface Pro and installed VCM Suite, installed all of my tunes and logs and am having a problem getting the VCM scanner to display my histograms properly - namely the column (top) axis headers. I've tried moving the VCM Scanner folder from the old laptop to the new one, double-checked that the table displays match, rescanned the car, uninstalled and reinstalled VCM Suite and still have the same problem.
The problem is that the majority of my column headers all show 0.0 and when I try to change them, it will not give me any options other than :1 in the secondary area in the Row & Col Axis tab. On my old laptop, the secondary area shows % which is what I need to change to in order to get the column headers labeled properly but I don't have the option to change to % there.
I've read and tried everything I've found here to make them change but have had no luck and have exhausted my searching efforts. I'm sure it's something simple but I need help finding that simple solution and appreciate any help that can be offered.
Thanks in advance!
