This is maybe a very noob question in the GM world of tuning. I havent done much SD GM stuff but switched my truck to a COS SD 1bar tune. Typically if tuning other platforms or standalones in SD their are target AFR's for each cell as you go up in rpm and kpa. Typically over 50kpa i start enriching my targets. 0-50kpa 14.6, 60-75 13.8, 75-100 13/12.8 ranges.
Problem is i have been using closed loop trims and looking at multipliers etc but nothing i see changes from 1.00....
Should i make changes to Open loop EQ ratio (this is the only table that looks like a target table). But its open loop and when i go in clossed loop will it be ignored?
I have purchased and read a few tuning documents but nothing i have read has been very clear on targets. I assume if i did a 2bar 3 bar SD tune you would want to dial the cells in also. Then work PE into the mix... Sorry guys just confused at the moment, probably over thinking something simplistic.
