Results 1 to 8 of 8
Thread: Just curious
    Oct 2014
    5
    Just curious
    The car has a comp XER281H cam, ported 706 heads, and a fast 90 with 90 TB.
    Managed to get a 7.17 in the 1/8 with this tune. I know the injectors need changed, but I am
    just curious to see if I am on the right track. First time tuning so I am proud of myself but clueless if I have made any mistakes lol.
    Thanks in advance
    third pass 7.17.hpl
    up timing.hpt
    Tuner POWERZONE's Avatar
    Jul 2014
    HOUSTON,TX
    191
    At a quick glance, your spark tables need work.
    Can you list out the combination.
    POWERZONE- AUTOMOTIVE PERFORMANCE AND TUNING SOLUTIONS
    STREET TUNING/DYNO TUNING/TRACK TUNING/REMOTE TUNING/EMAIL TUNING
    [email protected]
    Oct 2014
    5
    1998 Trans Am
    2000 computer and harness
    Stock bottom end LS1
    ported 706 5.3 heads
    fast 90 intake
    Nick Willams 90mm Throttle body
    Comp XER281H cam
    Hooker long tube headers turned out just before trans x memeber
    stock 28lb injectors
    TH350 w/trans brake with 4000 stall
    Moser 9" with 3.89 gears
    Nitrous Express MAF kit (has not been used yet)
    pretty sure that's everything
    Oct 2014
    5
    Thanks for looking. I just wanted a piece of mind knowing that I was heading in the right direction
    Jul 2014
    HOUSTON,TX
    191
    You might wanna ease up on the spark advance, I think your KR is real in spots, especially since you are commanding 12.7-13.2 PE.
    I would zero out the tq management: engine>tq management> spark retard
    What is your actual AFR? If you are actually getting what you are commanding 12.7-13.2, then it looks like you are gonna need larger injectors. You are above 100+ duty cycle.
    [email protected]
    Oct 2014
    5
    I don't have a wide band so can't say on the AFR. I know for a fact it needs larger injectors, that has put me at a stand still until I get them. One thing I am not understanding is why the log says it was running 32 degrees going down the track yet the tune is only 28 degrees. Also I am running Sunoco 104 unleaded in the car.
    Jul 2014
    HOUSTON,TX
    191
    Quote Originally Posted by philricd02 View Post
    Well, your spark advance tables are showing that you are commanding 33*.
    Ahhh, I see with the 104 oct.
    I would suggest you get a wideband before tuning or doing more WOT pulls are passes.
    [email protected]
    Oct 2014
    5
    Ok I see what I did lol. I was looking at the same tune but with timing pulled to 28. I have been going over and over the tune while sitting at work. What sucks is the car is put for winter and is a track only car with just enough exhaust for the 02 sensors. So with that I can't test any changes until spring and the track is the only place the car goes. I will look at getting a wideband and figure out were to put it.
    Thanks for the help, there is so much to take in with this.
